Kfx50 stalls when wide open
Old Aug 19, 2019 | 08:24 PM
Gregcooney1's Avatar
Default Kfx50 stalls when wide open
I have a 2008 KFX 50 that runs in idles fine but when you slam on the throttle all the way open it stalls you can feather the throttle till it’s wide open and it runs but if you go full throttle from a stand still it dies. I cleaned the carb multiple times I even swapped a carburetor from Kfx 90 and it ran fine. Thanks
Old Aug 20, 2019 | 02:08 AM
If the main jet needle is adjustable, adjust it to give more fuel. If it isn't, get a new main jet. If that doesn't work, try a slightly bigger main jet, if you can get one.
Old Aug 20, 2019 | 06:26 PM
How would I know what size main jet is in there now
Old Aug 21, 2019 | 02:10 AM
Jets should have numbers stamped on them, on jets that small you may need a magnifying glass. Kawasaki manuals should have the information in them, and a Kawasaki dealer will be able to tell you what number is standard and what bigger jets are available.
Old Dec 4, 2019 | 06:21 PM
Fox44's Avatar
I had the same problem on my 2019 kfx50.
Dealer turned up the idle a screw and it no longer has this issue. When cold engine, it will big down but not die if you go from idle to wot.
Lander Walker
Jun 25, 2012 06:38 AM
carfan87
Jun 15, 2010 04:19 PM
sianod
Feb 27, 2007 01:26 PM
bbertram
Apr 28, 2004 12:57 PM
2manytoys
Apr 22, 2003 12:10 AM
