2009 Rancher...hit the gas and it sputters, help please.
Old Sep 5, 2019 | 11:09 AM
RedRancher's Avatar
Default 2009 Rancher...hit the gas and it sputters, help please.
Hi friends, so I have a 2009 Honda Rancher 420 4x4 electric shift (not the dual clutch auto). The problem is very odd, in short; Turn motor on, shift from neutral to first gear, hit the throttle and it sputters. Drop it back into neutral, rev it, shift back to first and it no longer sputters. Any ideas and next steps would be greatly appreciated.
Thank you.
Old Sep 6, 2019 | 02:11 AM
Er, blip the throttle before you put it in gear, most people do anyway. If it bothers you, treat it to a new fuel filter and plug. I sometimes blow the injector top out too, but that seems to make far more difference on Suzukis than it does on Hondas. If you are taking the injector out, the IACV will need to come out first, there is always carbon on it so a clean of that may help, it is very delicate so be careful.
Old Sep 6, 2019 | 11:03 AM
RedRancher's Avatar
Thank you merryman, I ordered a fuel filter and along with a new spark plug I'll be cleaning the petcock screen, the fuel injector and the IACV as you suggested. Hoping its just dirty
Old Sep 9, 2019 | 12:27 PM
RedRancher's Avatar
Following up to my main post.
Went through the entire fuel system over the weekend, cleaned the petcock, cleaned fuel lines, cleaned the injector (took out and sprayed injector cleaner through it while applying 12v to the leads to activate the injector). Thing runs great now. In the end I am almost 100% certain it was mostly the fuel filter when I took it out it was black and filled with debris.
Thanks again for all the suggestions.
svojibwayprincess@nodinwifi.com
May 26, 2018 02:09 AM
Chris2017
Sep 25, 2017 02:27 AM
jjkc
Mar 21, 2011 09:30 PM
Raptauru
Jan 19, 2009 01:45 PM
