Kazuma 110 new battery
Hi, thanks for the add...
I have a Kazuma 110, ran fine last year, drained gas, oil was good, stored in garage... i bought a new battery, put it in and when i try to start it, all i get is a clicking noise, it sounds and feels as if its coming from the starter.. Any suggestions would be great..
Thank you..
Thank you..
Check that new battery is fully charged. Check that the wires to it are connected tightly. If those are OK. I go for the 12v test lamp method. Use an incandescent bulb type, and connect one lead to the battery neg, other to the positive post on the starter motor, switch on, press start button, if you hear a click and the lamp lights, faulty starter. If you hear a click and lamp doesn't light, faulty solenoid.
