front spring spacers
Old Apr 25, 2001 | 10:15 PM
badhabits's Avatar
well, tonight i was feeling a bit self destructive and put on some front spring spacers ala cowboy.
i took off the top shock bolt, turned it down and used 4 9" visegrips(2 at a time) to compress the spring. zip tied them after they locked(an added safty measure, lol). pried the rubber bushing down with a screwdriver, took off the collar lock widget then slid the spring off very gently. i took off the plastic spring spacer and washer, added a 3/8" piece of 1 1/2" sch. 80 pvc right over the bottom part then put the whole thing back together.
took about 20 minutes per side including finding the tools. i'll ride it tomorrow and see how i like it. i think its going to be a bit harder ride.
Old Apr 26, 2001 | 02:49 AM
cowboy's Avatar
Badhabits:
With no weight up front, yeah, it will be much more rough than what you're already used to. I think you'll find though that it will nearly eliminate any of the "body roll" that you might find while cornering hard at higher speeds. I carry over 100 lbs. up front at all times, so I don't notice it as much as a stock machine with no weight would. If it's too much, you could drop it down to 1/4", maybe put the 3/8" or even a 1/2" in the rear. I don't suppose you took any before and after measurements did you? Just curious to see what you got out of them. I gained 1 1/2" of ground clearance myself, but have heard numbers range from 1-2" overall.
Anyway, best of luck, if you don't like it at least it was free, or at least cheap and easy to fix!
Mike
Old Apr 26, 2001 | 10:35 PM
badhabits's Avatar
cowboy
before the installation, under the frame in front with no weight was 10". after it was 10 7/8.
when i did the rear it was 9" under the frame just in behind the plow bracket. after it was 9 3/4.
both were done with 3/8" pvc spacers. i think i'll drop the front down to 1/4" and see if it's a little more compliant. i didn't load it up but my wife doesn't ride with anything on the bike.
she gets mad when i forget to take the husky off because she can't undo the bungees. lol. i'm sure the 1/4 will be fine...with somw weight on board. kinda equalizes it out.
she can't steer it with 6 concrete chimney blocks on it..........
Old Apr 26, 2001 | 10:36 PM
badhabits's Avatar
Old Apr 27, 2001 | 08:54 AM
sxr6's Avatar
hey guys to retain the softer ride & I don't carry much weight anyway, I raised lower shock mount up about 1" on the front & lowered upper shock mount about 3/4" on the rear.
ghost civic
Jan 15, 2020 07:43 AM
carolinabomb
Jul 26, 2015 08:40 AM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
