1999 sportsman 335 Oil drain pan threads stripped
Old Oct 16, 2019 | 08:12 PM
keizer's Avatar
Default 1999 sportsman 335 Oil drain pan threads stripped
I have a 335 sportsman with the oil pan threads that are stripped. Can anyone offer suggestions on how to fix this. The oil pan in aluminum and the plug is metal. Thanks.
Old Oct 17, 2019 | 10:02 AM
Kymco 450i's Avatar
There are companies that make oversize taps and drain plugs. Do some searching, simply retap the hole and add the oversize plug. In some severe cases you might need to move up to the next larger plug size. I have went from sae to metric and metric to sae in order to get a slightly larger size to rethread an existing hole. I have also used button head screws with nylon washers to act as drain plugs when all else fails.
Old Oct 17, 2019 | 11:47 AM
keizer's Avatar
OK I will look around to see what the best option is. To bad the drain is recessed on the on the ATV which makes it harder to get a oversized plug to fit. Someone suggested using a Helicoil insert as a possible solution. Could this work.
Old Oct 17, 2019 | 12:33 PM
keizer's Avatar
What is the size of the oil drain plug for a 1999 Sportsman 335?
Old Oct 17, 2019 | 03:19 PM
Kymco 450i's Avatar
Helicoil would work but might drip a little.
Old Oct 17, 2019 | 05:04 PM
keizer's Avatar
That’s what I have read. What is the size of the drain plug so I can match the right helicoil kit for it. The plug says M12 which suggests a metric bolt.
Old Oct 17, 2019 | 05:38 PM
Kymco 450i's Avatar
M12. Would be a 12mm dia metric bolt. Most any hdwe store has a bolt gage that will give the pitch of the thread.
Old Oct 17, 2019 | 06:32 PM
keizer's Avatar
I will check this out. Thanks for the information!
chris589
May 12, 2009 09:43 AM
gaugedholes
Nov 17, 2008 01:12 PM
BART323
May 31, 2004 09:02 PM
TheWayOut
Nov 21, 2002 07:31 PM
