LT80 plunger assembly
Old Oct 27, 2019 | 02:54 PM
bosnian999's Avatar
Default LT80 plunger assembly
Do the plunger assembly on these wear out.Just cleaned the carb and took the plunger assembly out and now it wont stay in the open position.Have I dropped something or has the cleaning just shown that it is worn..Thanks for any help.
Old Oct 28, 2019 | 08:12 AM
LT80's Avatar
LT80 Expert
Normal IMO.
Old Oct 29, 2019 | 03:21 AM
Not being very helpful Jack. If I remember rightly there is a groove in the rod and a sort of R clip in the bit that screws into the carb. When you pull the plunger up, the clip springs into the groove. When the rod gets worn or clip looses "springiness," the plunger won't stop up.
Old Nov 3, 2019 | 09:34 AM
bosnian999's Avatar
Ok thanks.
Obvious question is can you replace these as I think mine has fallen off or lost when I started to work on the carb and dismantled everything.If not I am assuming you can replace the whole plunger assembley
Old Nov 4, 2019 | 02:48 AM
It only comes as an assembly. I did once make a replacement clip up out of mig welding wire. It sort of worked, but like Jack wrote above, non of them work too well after 20 years of wear anyway.
Old Nov 17, 2019 | 01:24 PM
bosnian999's Avatar
Bought a replacement and fitted.Now just got to get the thing to start and run consistently.Think new plug in order as air filter done and carb cleaned.
hilsy
Oct 17, 2016 05:31 PM
THE CARP MAN
Feb 27, 2013 06:22 PM
volfan537240
Oct 2, 2012 10:07 AM
YZOtis
Mar 22, 2007 01:11 PM
