Coolster 110cc drives while idling
Old Nov 17, 2019 | 10:23 PM
Doom's Avatar
Default Coolster 110cc drives while idling
Hello I have a coolster 110cc that will drive by itself at idle. It is still drivable but you have to hold the rear brake while at stop . I have had this ATV new since 2017 and have not done any modifications... I have played around with the idle screw with no success thank you.
Old Nov 18, 2019 | 02:52 AM
Have you slowed the idle down to stalling point? If it still "runs away" at this engine speed, you have a problem with the clutch. No idea what type a Coolster has. Most circa 110cc bikes have a lawnmower style centrifugal, but some of those using variable belt drive just let the belt get slack enough to slip at low revs.
Old Nov 18, 2019 | 09:16 AM
Doom's Avatar
Thanks for the reply ,It’s a 3050C...the problem is still present but way better at low idle...thing is where we ride is high altitude so I usually have to crank up the idle really high to keep the atv from not stalling..and that’s when it really wants to take off ...
Old Nov 19, 2019 | 02:46 AM
I don't normally recommend touching the idle jet, but your circumstances dictate that the standard setting may be rich, lean it down a little, and you may find you can sustain a lower idle speed setting.
spcamno
1) Engine problems..
Jun 4, 2011 05:57 AM
bobr
Jun 16, 2010 06:24 PM
