110cc clutch sticking
Old Sep 7, 2009 | 10:09 PM
spcamno's Avatar
Default 110cc clutch sticking
A buddy of mine has a 110cc mini hummer with automatic and the clutch seems sticking.
It will start taking off even at ldle (slowly though) we both have tried adjusting the slotted bolt on the right side of the engine but seems no difference.
Had the clutch apart and nothing seem unusual no broken or worn parts.
Using the right oil (Rotella T) and everything seems right but can't figure out what's wrong anyone has idea what to check next?
Thank you in advance!
Old Jun 4, 2011 | 12:02 AM
NoLuv4Hoes's Avatar
Adjust the idle screw on the carburetor simple as that
Old Jun 4, 2011 | 05:57 AM
snow racer's Avatar
Its full auto, right? Because if your idle is to high your cluch will seem to engadge to early. So if you turn in the idle screw it wont do that. Also do you start at idle then slowly get faster.
mywifesquad
8
Sep 21, 2015 08:20 AM
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
