1999 Polaris Sportsman 335 ATV oil leak.
I have a 1999 Sportsman 335 with a engine oil leak on the right hand side of the ATV. There is a small hole maybe 1/8" in diameter and when the ATV is turned on it is blowing oil out this small hole. Looks like there should be a plug there but I don't see one. Any help would be appreciated.
If you cant find a reason for it, just tap the hole and put a screw in it. The aluminum housing should be easy to tap. Use a stainlees steel screw so it doesnt corrode in place. Just my two cents....
I took the cover off where the water pump would be if the ATV had one. There is a oil seal that came out of place. How big of a job is it to replace the seal.
Mine leaks after shutting off. It leaked about 5 ounces then stopped leaking. I drove it all weekend and it didn't leak too much after that.
Could it be an oil overflow?
I just changed the oil and put in 2 quarts. I did not drain the lower bowl of oil.
