2002 Rancher 350 Head Bolts (not the nuts) Torque
Old Feb 16, 2020 | 07:59 PM
New Hampshire Patriot's Avatar
Default 2002 Rancher 350 Head Bolts (not the nuts) Torque
Anyone know what the torque spec is for the 2 bolts that sit outboard of the push-rod on the head. These are 2 long 6 mm bolts not the 4 main head nuts.
I don't see a value listed in my manual.
TRX350FE
Old Feb 17, 2020 | 02:41 AM
I don't think they are listed, Honda expects common sense, so you tighten them like any other M6 bolt, oil filter for example. There can be a problem with them, I have known many to be seized and snap rather than come out when dismantling, and the odd one to strip the thread at a far lower torque than normal. Rocker cover bolts sometimes strip threads this way too, I think if the engine has overheated due to oil shortage, it softens the aluminium.
Old Feb 18, 2020 | 04:54 PM
1 of mine broke off and I had to use a welder to get it out. I'll be light on the torque, worst case it will seep a little at the base gasket.
gelee
Feb 26, 2008 09:30 PM
the75animal
Jul 15, 2004 12:21 AM
hawleywood
Apr 15, 2004 01:18 PM
Haulinonthedunes
Feb 20, 2004 10:02 PM
