Starting Issue
Old Feb 27, 2020 | 09:51 AM
Gregrey's Avatar
Default Starting Issue
2017 Polaris Sportsman 570 EFI. When I turn the key to start the engine it clicks as if the battery is low but I have a new battery fully charged. If I keep working with it, she will eventually turn over and start. I replaced the starter solenoid but the issue persist. Help!
Old Feb 27, 2020 | 09:53 AM
scootergptx's Avatar
Supersock
Hired Gun!
Check the ground cable to see if it's tight and clean.
Old Feb 27, 2020 | 12:22 PM
Gregrey's Avatar
WIll do. Thanks!
Old Mar 9, 2020 | 09:44 AM
Gregrey's Avatar
I had the same issue with my 570. I replaced the battery with AGM 310 CCA and I have had no issues with it turning over since. It required a modification to the battery case.(flattened the back side and turned a .25 inch lip on the end) Also bent down the rear frame battery tab to accommodate the longer battery. All of this was easy to do with the front, left tire removed.
Old Mar 9, 2020 | 12:54 PM
csmith16's Avatar
i would check the plugs
wolfjon
Apr 27, 2019 05:19 PM
JSRIII
Sep 2, 2018 11:33 AM
Dageaux504
Jan 22, 2017 05:38 PM
kcenderjim
Mar 14, 2012 03:29 PM
dagoth
Feb 10, 2010 10:31 PM
