Charging issue
Old Mar 20, 2020 | 11:43 PM
Austin Brooks's Avatar
Default Charging issue
So I have run across a problem I tried to rob power from my ignition and now my 3 wheeler won’t charge at all anyone know what to do I have checked all the fuses and grounds
Old Mar 21, 2020 | 02:51 AM
You don't mention the model. The charging circuit is simple, two or three wires from alternator to regulator and a pos from regulator to fuse then battery and a neg from regulator to battery earth. You must get full battery power on both earth wire and pos wire at regulator, any resistance and the reg will not charge the battery. I always test this with an incandescent test lamp, (after once changing a stator and finding no improvement, I had tested battery wires with a voltmeter, and was getting volts, but there was no power getting through them due to corrosion inside the wire).
Libertynow
Technical and How-To Articles
Aug 13, 2016 01:55 PM
squeege
Nov 7, 2006 10:43 AM
yoda
Jul 9, 2005 11:29 PM
1prokiwi
Oct 21, 2001 08:50 PM
