Dinli 50cc Bogged down no power.
Hi all,
Got a Dinli 50cc (I believe it's a minarelli engine) previously was running fine. But I had to change the Air filter due to damage to the tube between the carby and air box. So I changed it over to a Pod style filter and since changing it the ATV has no power to move the bike.
idle is fine, starts straight away no issues all sounds well but when you give it some throttle it's just bogs down.
I'm thinking that there is lack of fuel (main jet to small) so open up carby and main jet is a MV11-22 95 which I would have thought would be high enough.
also adjusting the air adjustment on the carby doesn't seem Todo anything
Since changing the air filter I have also re-wired the whole bike with a new wiring kit but every thing seems fine wiring wise. Not sure if a CDI could cause this.
