10A ignition fuse blows as soon as key is on.
Old Apr 8, 2020 | 06:45 PM
Cwallz82's Avatar
Default 10A ignition fuse blows as soon as key is on.
I've got a 1998 honda foreman 450es. As soon as I turn the key on it pops the fuse. Any ideas where to look?
Old Apr 9, 2020 | 06:50 AM
Which fuse, main ir ignition?
Old Apr 9, 2020 | 09:50 AM
Cwallz82's Avatar
The ignition fuse keeps blowing as soon as key is on.
Old Apr 10, 2020 | 02:13 AM
Switch the kill switch to the off position, Switch the ignition on, if the fuse does not now blow, unplug the CDI and switch the kill back to run. If the fuse still doesn't blow, you have a faulty CDI. Check the green/white earth wire to the CDI is a good earth, I use a heavy wattage test lamp for this, then fit a new CDI. Fuse should not now blow. Start engine and check how many volts you get across the battery, if you get more than 15v, shut off again before you blow another CDI and buy a new regulator as well.
Old Nov 15, 2022 | 07:15 PM
jake34's Avatar
What did you find out? I have the same year same atv doing the same thing
iceman4757
Jun 8, 2019 02:10 AM
maxlacy
Apr 2, 2009 11:03 PM
doekilr
Jul 20, 2008 01:56 AM
02BAJA
Jul 11, 2002 09:28 PM
