Prairie 400
Old Apr 18, 2020 | 08:11 PM
Xgrunt's Avatar
Default Prairie 400
2001 prairie 4000 4x4 rear wheels not pulling at all
what should I look at first
Old Apr 18, 2020 | 08:25 PM
MrSummit's Avatar
Not pulling, do you mean no power getting to the rear wheels?
I would remove the rear diff fill cap and take a peek. Fluid? Fluid look good? If you can see the gears, do they look good?
Old Apr 19, 2020 | 12:10 PM
Kymco 450i's Avatar
Pop off the belt cover and see what condition the cvt belt is in. Belt failure from age or abuse is common...
Old Apr 19, 2020 | 05:48 PM
MrSummit's Avatar
Belt cover removal is a pain on these. Have to remove running board and brake pedal. The brake pedal spring is not fun to reinstall. I drilled an access hole in the plastic to make removal of one belt cover bolt easier, the upper rear.
Maybe there is an easier way to remove the cover without removing the running board and the brake pedal. Actually, the most miserable part for me is installing the brake pedal spring during assembly.
If someone knows an easy way to install the spring let me know.
AtomicAustin
Jan 28, 2002 11:11 PM
AtomicAustin
Jan 27, 2002 07:30 PM
GLBanks
Apr 29, 2000 05:25 AM
