Prairie 400
Belt cover removal is a pain on these. Have to remove running board and brake pedal. The brake pedal spring is not fun to reinstall. I drilled an access hole in the plastic to make removal of one belt cover bolt easier, the upper rear.
Maybe there is an easier way to remove the cover without removing the running board and the brake pedal. Actually, the most miserable part for me is installing the brake pedal spring during assembly.
If someone knows an easy way to install the spring let me know.
