how to check timing on 220 bayou?
Old May 23, 2020 | 04:25 PM
cjben's Avatar
Default how to check timing on 220 bayou?
Getting fuel and spark,need to check timing. Procedure for a 1999 bayou 220?
Old May 24, 2020 | 04:12 AM
Remove big cover plate on side of cylinder head, move crank round until timing mark for 220 on sprocket lines up with mark on head. Remove screw from TDC hole in alternator case and check the TDC mark is lined up. A millimeter or two out is OK. If it is miles out, check that the flywheel hasn't slipped, by taking the spark plug out and checking the piston really is at TDC.
Non staring is far more likely to be low compression due to piston seizure or a valve stuck, than slipped timing.
Dutch-guy
Oct 9, 2010 03:35 PM
redneckfromnb
Jul 13, 2008 04:26 PM
weezerocks
Jul 3, 2004 06:14 PM
VinnyYZ
Oct 28, 2002 06:31 PM
