Need help with 1998 polaris 500 carb
Old May 24, 2020 | 02:40 PM
SnowWhiteHawk59's Avatar
Default Need help with 1998 polaris 500 carb
Hey man I just got a Polaris 500 1998 from a guy and he had the wrong carb on it so I ordered another carb and it fits but I’m missing the clear line that run out on the front of the carb. The two gold ports coming out on the carb but I can’t find anything to hook it up
Old May 25, 2020 | 08:39 AM
Nomicron99's Avatar
Looking at a parts diagram on the front left and rear left side it shows two caps so i believe the two ports are just blocked off.
Old May 26, 2020 | 05:46 AM
The two gold ports is on the side facing the air filter is that vacuum or what?
Old May 26, 2020 | 07:18 PM
Nomicron99's Avatar
Try looking here. They have the parts diagrams listed for every 1998 Polaris. you may be able to figure it out looking at them.
https://www.cheapcycleparts.com/oemp...atv_1998/parts
Old May 31, 2020 | 12:43 PM
I’ve dug further into the four wheeler it seems to not be getting gas and vacuum any assistance would be great
Old May 31, 2020 | 01:06 PM
Nomicron99's Avatar
Might be a bad fuel pump? or clogged fuel filter? In my limited experience with this type of setup there is not alot of vacuum at the fuel pump. Also the vacuum is not constant it is a pulse that moves a diaphragm back and forth to pump the gas.
Low pressure and low volume nothing like a automotive fuel pump.
Old Jun 1, 2020 | 06:11 AM
I have ordered a fuel pump and might possibly get it today. Does the clutch boot give vacuum or cause vacuum? I’m just curious because I was looking at the tube coming from the clutch and the boot is torn.
Old Jun 1, 2020 | 06:23 AM
Nomicron99's Avatar
No its crankcase that provides the pulse.
HARLEY_OWNER
Mar 14, 2009 08:18 PM
Erod
Oct 11, 2006 11:16 PM
ZillaRider87
Dec 5, 2004 06:50 PM
xplore50097
Jun 25, 2003 09:22 PM
jetsnow600
Mar 4, 2003 03:27 AM
