Sport Quads Discussions on sport quads.
1999 Polaris sport 400L leaking ????
Old Jun 11, 2020 | 01:25 AM
Jhutchsport400's Avatar
Default 1999 Polaris sport 400L leaking ????
Hello everyone. My first post on here! I just purchased a 1999 Polaris sport 400L
I had some fuel leaking from the bigger tube by the rear shock took the carb apart seated the needle everything looked good put back together and now leaking through the smaller tube on the left of the rear shock ?? And when i Say leaking I mean puking out even when Its rolling flat... even when gas is off??? Any help is appreciated.
Also where can I find the counter balance drain & fill plug?? THANK YOU!! Pictured below is both tubes!! Only leaking out of the smaller one now
UPDATE!!! RAN THE QUAD WITH GAS OFF TO CLEAR LINES THE LEAK HAS STOPPED FOR NOW. CARB WAS GOOD MAYBE JUST DIRT IN LINE OR LOOSE BOLT????
AFTER LAST UPDATE I LET QUAD SIT FOR 2 HOURS GAS STARTED TO LEAK AGAIN (still in off position) and quad started right up???
Theodore Falce
Jun 3, 2020 04:19 AM
onasport400
Oct 23, 2009 03:41 PM
ThePunisher
Jun 18, 2003 02:12 PM
BigNasty15
Jun 10, 2000 02:02 AM
khaynes74
Feb 10, 2000 01:24 PM
