98 Sportsman idles great cutting out at full throttle
Old Jul 8, 2020 | 05:30 PM
catronjl's Avatar
Default 98 Sportsman idles great cutting out at full throttle
I have seen pages of posts on this problem but think mine is strange. If I cover the inlet tube to air box revs up and runs good but if not cuts out and backfires. Is this a fuel issue???
Old Jul 9, 2020 | 07:04 PM
Nomicron99's Avatar
Check the intake adapter between the carb and engine. You will probably find it torn.
Old Oct 16, 2020 | 11:31 AM
catronjl's Avatar
I checked intake boot. No tears! Still can’t get it to open up unless I restrict the air! What am I missing????
Old Oct 16, 2020 | 02:40 PM
Nomicron99's Avatar
Sounds like you need to do a good carb clean and rebuild. Don't buy a cheap Chinese carb off ebay or you may end up with worse problems.
Old Oct 16, 2020 | 03:03 PM
catronjl's Avatar
How do I tell if someone has went with a Chinese carb in the past??
Old Oct 30, 2020 | 05:48 PM
catronjl's Avatar
Ordered a carb off eBay figured I’d try it! Put it on and this thing runs like a top!
Old Mar 14, 2021 | 07:53 AM
Glynnk1981's Avatar
it sounds like the common problem with these particular at a, & that is the cam going flat and exhaust rocker worn.
agman
Apr 15, 2021 05:31 PM
spark1051
Jan 18, 2015 08:53 PM
dannypz
Apr 11, 2005 03:05 PM
BoHunter
Feb 27, 2004 02:42 PM
IsaacWD
Oct 5, 2003 09:54 AM
