Spark,fuel,air but won’t fire
Old Jul 9, 2020 | 10:44 AM
1950jl's Avatar
Default Spark,fuel,air but won’t fire
I set timing as required and checked it many times. Set the valves, new carb and checked the fuel. Turns over great with great spark.
Question; is it possible that the spark timing is off? Can the cdi cause an advanced spark condition or something else? I also check the shear pin. I am lost? I thought I was good at this till this quad!
Old Apr 27, 2022 | 04:57 PM
Paramedicdan's Avatar
All internal combustion engines require 4 things to run. Fuel, Air, spark, and compression. If you have fuel, air, and spark then check compression.
Crackerjackie
Feb 25, 2019 02:11 PM
Hopej
ATC 3-Wheelers
Jan 13, 2015 10:35 AM
madmax1398
1) Engine problems..
10
Mar 21, 2013 06:04 AM
dx787
3) General Discussions..
12
Aug 2, 2011 07:08 PM
millwrightullom
ATC 3-Wheelers
Oct 24, 2003 06:26 PM
