2002 Honda rubicon 500 wont downshift Help!!!!
Old Jul 16, 2020 | 11:56 AM
Jencat's Avatar
Default 2002 Honda rubicon 500 wont downshift Help!!!!
2002 Honda Rubicon wont down shift. Driver 1 driver 2 and esp no foot shift, 1st start will run up the gears no prob. Soon as I try to shift down starts flashing and is stuck in high gear until I turn off and back on. When it flashes it does it non stop and there are 2 dots on the screen also.... replaced angle sensor no help just put 2000$ into it and want to get it rite... any ideas?
Old Jul 17, 2020 | 02:14 AM
Does it run down the gears in Auto? The 500Auto is Electro hydraulic CVT so, in auto, it should just change down imperceptibly as it goes up hill, and you would find it back in bottom gear if you slow to a stop and set off again. If it works OK in Auto, most likely your downshift button isn't working properly for ESP shifting. If that isn't the fault, could be best to let a Honda dealer fix it, as it is a very complex system electronically. The angle sensor is pre-loaded on the Auto, did you fit it properly?
Tattoodad5
May 23, 2017 02:54 AM
patrick.oc123
Sep 16, 2015 03:45 AM
jemco
Feb 18, 2013 10:25 PM
AEW
Apr 27, 2007 12:24 PM
ATV_MAN
Nov 29, 2000 10:23 PM
