Suzuki LT230E 1987 - Starter Relay/solenoid Wiring
Old Sep 28, 2020 | 08:21 AM
BackYardBusiness's Avatar
Default Suzuki LT230E 1987 - Starter Relay/solenoid Wiring
Hello guys.
Found this quad for a decent price recently. Runs and drives but the wiring is a mess. Previous owner did some self modifications including a hotwire job for the starter solenoid / relay.
I've got the wiring diagrams but non of my wires that run to the rear are factory colors / mismatched wires.
I need a little help grasping where the all the rear wires go (Tail light, starter relay, grounds) etc.
Pictures / notes any info would be great!
Thanks in advance.
PS: First thread/post here but most likely wont be my last with this project.
Old Oct 2, 2020 | 02:34 AM
Kieran Martyn John's Avatar
Originally Posted by BackYardBusiness
Hello guys.
Thanks in advance.
Assuming everything is working the lives should be pretty easy to work out with a volt meter, just make sure you've got a good ground then put the live to one wire at a time and toggle through your switch gear, when you get a reading you know it's for whatever you've just switched on.
Ace1996
1) Engine problems..
14
Nov 26, 2020 09:48 PM
djcheez
Sep 29, 2011 11:26 PM
panther25
Technical and How-To Articles
Jul 13, 2009 11:53 AM
timber two
Sep 3, 2007 07:28 AM
R00ST
Mar 28, 2007 11:59 PM
