Lt80 piston
Old Oct 4, 2020 | 11:54 AM
Nick.m's Avatar
Default Lt80 piston
Anyone know why this would build up so much carbon after about 3hrs after rebuild ?
Old Oct 5, 2020 | 03:13 AM
Probably too much oil in fuel/oil mixture, or rich air/fuel mixture in carb. The big question is why you needed to take the cylinder off 3hrs after rebuilding the engine.
Old Oct 5, 2020 | 07:02 AM
Nick.m's Avatar
Good question... noticed the head nuts had come loose so wanted to check head gasket was ok. Also noticed that the replacement head bolts were about 10mm shorter than the originals which could be why they came loose. New ones ordered. Will try adjusting the circlips on the needle. Cheers
Old Oct 5, 2020 | 09:47 PM
LT80's Avatar
LT80 Expert
Please install Suzuki studs. As you see, the cheapo studs stretch.
Old Oct 6, 2020 | 01:15 AM
Nick.m's Avatar
I've ordered genuine ones. Hopefully back together tonight
C Elwood
Nov 17, 2019 11:14 PM
Bobby Giroux
Sep 5, 2018 12:39 PM
Rahmelo Malik
Trick and Stunt Riding Photos
Oct 28, 2015 09:29 AM
burgezz
May 5, 2010 09:57 PM
