C70 Carburetor - Dual Fuel lines
Old Nov 25, 2020 | 09:38 PM
g_speran's Avatar
5 Year Member
Default C70 Carburetor - Dual Fuel lines
Hello All,
I am looking at replacing a c70 carburetor on my grandsons MPX70 atv. The carburetor that I am looking at looks like it has 2 fuel lines going into the carburetor shut off valve.
Can someone tell me the purpose of the dual fuel supply lines, if that indeed is what they are and how I actually connect them properly?
thanks is advance
Dual fuel line into carb?
Old Nov 26, 2020 | 03:08 AM
The reason for two lines is one is for main and one for reserve pipes from the tank. So if your existing carb doesn't have two lines from the tank, you can't fit that carb. In my opinion, putting the tap on the carb is a stupid idea anyway, as you need to be able to remove a carb without draining the tank, so taps should be on the tank, or in the fuel line.
Bill Hilly
Jan 16, 2020 01:35 PM
Hossrod
3) General Discussions..
Apr 19, 2019 07:49 AM
LoneWolfInArizona
Nov 13, 2006 05:07 PM
DaveP
Sep 12, 2005 01:34 AM
eRo
Aug 29, 2004 12:26 AM
