1995 big boss 400 stator upgrade?
Old Dec 9, 2020 | 11:34 PM
retterf's Avatar
Default 1995 big boss 400 stator upgrade?
I want to upgrade the charging system on my 1995 Big Boss 400l. I want to convert to a DC CDI and see if I can find a 3 phase stator that might fit under the flywheel.
I understand the I would need to change the regulator (possibly mosfet) and may need to upgrade the wiring as well. The charging system does not have enough umpf to run the plow winch and all the niceties for very long.
I did replace the factory size battery with a Harley battery and that helps. Any one ever dabble in converting to three phase? Since I will be converting to a DC CDI I don't need the ac coil on the stator and would like to find a stator that might fit with all charging coils.
Old Dec 12, 2020 | 05:02 PM
Yooper265's Avatar
I've never seen a larger statot / upgrade for these , my brother in law has a ranger 6x6 and had same problem , I made a bracket and installed a full size Optima battery , no more problems . If you do a lot of plowing just put a trickle charger on it when you're done .
Old Dec 12, 2020 | 05:32 PM
Yooper265's Avatar
This is what I put on my Ranger 570 when I bought it , still working great .
retterf
Dec 9, 2020 11:33 PM
Delox
1) Engine problems..
Sep 29, 2012 12:12 AM
m_mowat
Dec 6, 2008 01:05 PM
lotus4s
Jun 29, 2007 02:29 PM
PUSHINTHELIMIT
Dec 13, 2003 08:50 PM
