Engine rebuild...... Top end rebuild?
Old Apr 30, 2001 | 10:33 AM
sparkster's Avatar
I was wondering the what the difference is between the two. How do you know when to rebuild your engine or top end?
What will it change performance wise?
How are they done, is it easy?
How much $$$$ does it cost?
Please if you have any information share it. Thank you
Old May 1, 2001 | 12:19 AM
sparkster's Avatar
Doesn't anyone have any idea or info for me. I need my quad to be running top notch 3 weeks from now and need to know. Please give me some input.
I'm sure someone has rebuilt there engine before.
Old May 1, 2001 | 12:55 AM
NewDSLover's Avatar
Engine Rebuild normaly is top and lower end. Bearings, seals, etc. in the bottom end. Now a top end rebuild will be around $200, that's a bore job, piston, rings, gaskets, etc. A good thing to do is re-ring atleast once a year on a 2 stroke. This is only the price of the gasket kit and rings. While re-ringing you can check out piston, cyclinder, connecting rod, etc. It's also a good idea to replace the needle bearing during this. From what I've seen and done, you'll do a top end rebuild many times over before you'll have to do a lower end. Good Luck and hoped this helped.
slowgsxr97
Mar 18, 2022 03:40 AM
kelleycully
Sep 15, 2016 02:57 AM
Big bousse
Sep 26, 2015 10:42 AM
ghost civic
Jul 27, 2015 03:15 AM
hondarider1234
Jul 21, 2015 11:53 PM
