1997 Scrambler 400 4x4 compatibility
Old Jan 26, 2021 | 09:19 PM
Rhino58's Avatar
Default 1997 Scrambler 400 4x4 compatibility
I bought a bit of a project. I am in the process of rebuilding both the gear case and engine, but have found that I have a worn output shaft for the transmission (at the outer seals) and also where the water pump seals fit onto the balance shaft. I have found an xplorer 400, of a similar vintage. Would the transmission from the xplorer fit in the scrambler?
Old Jan 27, 2021 | 10:34 PM
Rhino58's Avatar
Default Scrambler 400 Shaft Repair
Alternatively, has anyone had any luck using Wear Sleeves or Speedi Sleeves? If so, where did you find them.
DaveRuane
Feb 27, 2004 08:41 PM
scrambansheeman
Sep 10, 2002 01:13 AM
highoutput2cycle
Sep 19, 2001 05:31 PM
PolarisPRO
Sep 19, 2000 01:36 PM
