1995 Sportsman 400 Compression release
Old Mar 22, 2021 | 12:34 PM
craig c's Avatar
Default 1995 Sportsman 400 Compression release
My 1995 Sportsman 400 4X4 wont start. At first I thought the battery was just not powerful enough because is was struggling to turn over so I charged it still wouldn't crank. My recoil was broken so I replaced it and realized it was so hard to pull it felt like I was going to rip the handle off and it would just about move. So I removed the spark plug and it cranks freely with both recoil and starter. I'm thinking it must be compression locking some how. I looked in the shop manual and don't see anything on compression release so I'm stumped. Can anyone give me some advise as to what to check next? It's like the exhaust valve is stuck shut but it's a 2 stroke.....
Old Mar 22, 2021 | 11:00 PM
FlawleZ's Avatar
Classic Yamaha Fan
If you suspect the exhaust valve may be stuck shut I would just check the valves to see if they're out of spec. If it's been sitting for a long time exposed to the elements its possible the exhaust valve rusted or has build up preventing it from opening.
Old Mar 23, 2021 | 06:52 AM
craig c's Avatar
FlawleZ - Thanks for your response. It's a 2 stroke so there aren't any valves, just a reed box on the intake side and and exhaust port in the cylinder wall I believe. but somehow it is getting compression bound.
Old Mar 23, 2021 | 01:54 PM
FlawleZ's Avatar
Classic Yamaha Fan
Oh ok I apologize I read that wrong. I wonder how it would do if you attempted to run a compression test?
VirginRider
Jul 24, 2020 12:01 PM
dan fredin
Aug 28, 2012 08:53 PM
knb
Jan 1, 2008 09:44 AM
darkfoxx
Nov 5, 2007 11:19 PM
azdave35
Sep 15, 2006 12:04 AM
