Honda 200s 1984
Old Mar 24, 2021 | 12:11 PM
Brad Lee King's Avatar
Default Honda 200s 1984
I have a Honda 200s 1984 and need to replace rear wheel bearings, but the axle wont slide out of the rear end after I detached the rear end from the bike. How do I get it our?
Old Mar 28, 2021 | 02:26 AM
Never done a chain drive Honda but the brake drum can get a grip on axle shafts. I have needed a power press to get them off and, on cockle picker's bikes, have even had to cut the drum off. On some Hondas a rubber ring, between axle and brake drum, has to be poked out before the shaft will come out. Surprising how good a grip it has on the shaft if you try to remove the shaft with it in place.
TStrudelhonda
Mar 14, 2005 10:37 PM
