Honda 200s 1984
Never done a chain drive Honda but the brake drum can get a grip on axle shafts. I have needed a power press to get them off and, on cockle picker's bikes, have even had to cut the drum off. On some Hondas a rubber ring, between axle and brake drum, has to be poked out before the shaft will come out. Surprising how good a grip it has on the shaft if you try to remove the shaft with it in place.
