Trail boss 330 issue
Old May 8, 2021 | 08:01 PM
coliv84's Avatar
Default Trail boss 330 issue
I recently bought a 03 trail boss 330 never owned atv before. I'm having an issue I need help to figure out it will start right up takes a few minutes to warm up then drives grate went for a ride last weekend it ran about 30 min and stayed out wen idle the battery was dead so put it on the charger and today did oil change and rode it for about 15 min out back then wen idle for about 10 min it stalled About 10 min later it started perfectly and ran for about 30 min then stalled wen idle started right back up and along as I gave it throttle stayed running soon as I let of it stalled any ideas
Old May 9, 2021 | 07:37 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like your bike isn't charging correctly. put a voltage tester on it while its running and see how many volts it say. it should be around 13.5 volts if its charging.
Old May 9, 2021 | 10:10 AM
coliv84's Avatar
I'll give that a try thanks
Old May 14, 2021 | 04:07 PM
coliv84's Avatar
I put a tester on it and get no increase wen its on and or reved up i looked up some things that sed to check my stator with my meter on ohms 200 is lowest setting I get a reading of 1 for all three connectors wen connecting one lead to one connector and one lead to frame i get no reading at all for any connectors wen runing and meter on ac 200 lowest setting i get a reading between 19 and 20 on all three connectors dose this mean my stator is good
Uncle Munkle
Oct 11, 2020 10:39 PM
Montreal2970
Apr 14, 2008 01:11 PM
wyguy
Feb 15, 2002 11:57 PM
