2003 sportsman 500 no spark
Old Jun 11, 2021 | 05:37 AM
fivepointoh's Avatar
Default 2003 sportsman 500 no spark
I have replaced , kill switch, ignition coil, trigger coil, stator, voltage regulator, battery. I was getting an intermittent weak spark. NOW. I bought a used wiring harness but it looks slighttly different. Has a small black box on the wire from an atv wrecker. 2×3×1 inches about. Is this from a different year? Its missing the black wires on the igntion pig tail that goes to the throttle cable. Early vs late 2003 maybe? Anyhow wondering if i can make it work. Are all 500 engines the same mechanically? Hypotheitcally if its a newer wiring harness could i convert it? The old wiring harness is corroded and i have new wiring issues with it every year lol.... looks in way better shape.
Old Aug 8, 2021 | 06:10 PM
Anyhow i sent this harness back and bought a brand new oem harness thats year specific out of luck. Still no/intermitten one spark. I added an extra ground from frame to engine. I made sure battery was charged. I put a spark plug boot and wire on from a car because the one in box was too short with ignition coil. Still no spark. I think if the flywheel doesnt do it its probably a bent flywheel or worn out magneto bearings as per the manual states. Thats alright im restoring the quad. Anyway just hoped to get it going for hunting season
Davidinkinc
Jan 9, 2016 05:42 PM
Serrowell49
1) Engine problems..
May 3, 2013 01:37 PM
Hjwray
Oct 23, 2012 11:54 PM
yarnots
Jun 29, 2007 11:24 AM
zillademon
Apr 24, 2004 06:52 PM
