Wiring harness
Old Jul 6, 2021 | 05:27 PM
joe022's Avatar
Default Wiring harness
I’m looking for a new wiring harness for a bc-y110.
will any wire harness work for this atv? Can I delete the remote kill also by getting a different harness
Old Jul 7, 2021 | 01:58 AM
As a rule, if you know enough about electrics to fit a "universal" harness, you could have fixed the harness you already have. No idea what a BC-Y110 is but most 110s use a copy of the Honda cub engine. This can cause problems as, although most universal harnesses are for this motor, different alternators are used by different makers, some use two wires to rectifier, some three. Some harness sellers try to get round this by supplying a stator too, but flywheels can vary in size, so the flywheel may not fit the new stator.
Old Jul 7, 2021 | 07:31 AM
joe022's Avatar
I can repair the harness but a few of the connectors are melted and pins in connectors are trashed. It has the remote kill switch on it also which I don’t have the remote for that’s why I was trying to do away with it with new harness that don’t have it.
Old Jul 8, 2021 | 02:52 AM
New universal harnesses won't have a remote. Just make sure you get one with the right stator wire connections.
Mitch101
Oct 22, 2017 10:46 PM
magicinmywords
Feb 16, 2017 11:01 AM
AdirondackGal
Technical and How-To Articles
Jun 27, 2009 08:07 AM
