sportsman 90 - seriously low compression
Old Jul 21, 2021 | 02:05 PM
x64code's Avatar
Default sportsman 90 - seriously low compression
Hey Guys - been having a heck of a time with a 2004 sportsman 90 (2 stroke). I was reading 30psi on my old compression gauge so i replaced piston, rings, gaskets, bought a new gauge and its also reading 30psi.. Is there anything other than what ive replaced that would cause such low compression? perhaps crank seals or a something on the bottom end? any help would be much appreciated!
Old Jul 23, 2021 | 03:18 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you bore out or at least hone the cylinder when you redid the top end? crank seals would be below the combustion so should not be a fact of low compression i would think.
Old Jul 25, 2021 | 08:39 AM
LT80's Avatar
LT80 Expert
If you didn't have your cylinder bored to the next size piston, don't expect much to change. Seals can be a factor but not with that much loss of comp.
Old Jul 30, 2021 | 01:34 PM
Willshire's Avatar
Did you follow the break-in procedure to seat the rings. This will be moot if you didn't at least run a honing stone inside the cylinder. The cross hatched walls give the rings "their own surface" to seat to instead of trying to seat to the smooth surface created by the last set of rings. i imagine just a stone hone could be done once, maybe twice before you'd have to bore it or replace it. There can only be 3 places a 2 stroke could lose compression. The cylinder walls (rings), the cylinder head (gasket) and the spark plug/hole (broken, cracked, cross threaded).
our250t
Sep 7, 2009 05:58 PM
mabmadman
Dec 16, 2007 06:37 PM
azdave35
Sep 15, 2006 12:04 AM
gman41364
Jul 13, 2006 09:27 AM
