Belt slipping after a foot of water?
Old Aug 6, 2021 | 04:14 PM
Gonzee71's Avatar
Default Belt slipping after a foot of water?
I have a 2021 sportsman 570, I drove it into a puddle mabe 10 ft. Wide and about 1ft. Deep, barley over my floor boards and immediately had belt slippage WTF?! Anyone else have this problem?
Old Aug 8, 2021 | 01:59 PM
Powerranger262's Avatar
I haven't experienced it with mine, but have heard about an inner clutch cover leak. I believe you need to pull the cover, both clutches, and seal it up.
Old Aug 9, 2021 | 09:21 AM
Check to see if the CVT plug is loose or not threaded correctly. Check the bolts to make sure each is tightened properly. Don't overtighten. They strip pretty easily. If that doesn't work take the cover off and seal the rim of the cover before reinstalling. Silicon caulking would do the trick. Just don't get it anywhere else.
KVF700
May 1, 2004 11:41 AM
Ruffinit
Jan 11, 2002 09:11 PM
Balintawak
Apr 10, 2001 01:49 AM
