Buggy
Old Aug 27, 2021 | 12:39 PM
Blackbetty96's Avatar
Default Buggy
Hello I have a 04 250 quadsport that has been turned into a buggy. Didn't know the keyswitch had bare wires showing and they got against metal and now it won't do anything. I thought might have been cdi so I tried one off a 250 Ozark and still same thing it won't try to start no lights or anything. Any help would be greatly appreciated
Old Aug 28, 2021 | 01:47 AM
"the keyswitch had bare wires showing and they got against metal and now it won't do anything"
Hopefully, it will have blown the main fuse which is in the wire between keyswitch and battery. Sort the bare wires out, check fuse, check battery isn't flat, then see if you get power to keyswitch from that wire.
Old Aug 29, 2021 | 10:15 PM
That's what I was hoping but changed it out and still nothing
Old Aug 30, 2021 | 02:54 AM
Changed what out? Have you checked if you get power to the switch and, if not, trace the live from battery to fuse to switch. That wire has to be broken or has a bad connection somewhere.
Jdavis72111
Jul 17, 2017 05:03 AM
lilredneckamn
Sep 17, 2008 05:33 PM
antipoped
Jun 19, 2008 07:09 PM
