Could i make my 2003 AWD Honda Rancher 350 into a 2x4?
Old Sep 27, 2021 | 10:44 PM
Skizzorz's Avatar
Default Could i make my 2003 AWD Honda Rancher 350 into a 2x4?
I have a 2003 AWD Honda Rancher 350cc. I was wondering if i could make it into a 2 wheel drive? If i can what is the best and cheapest way?
Old Sep 28, 2021 | 02:13 AM
Why would you want to do that? Cheapest is to remove front diff, and prop shaft between engine and diff, then remove drive shafts from their outer CVs. However removing CV shaft from those outer CVs is somewhere between difficult and impossible, you could always cut them close to the CV joint. Easiest is probably to remove prop shaft and front diff and fit the whole A arm/hub assemblies from a 2WD 350, if you can find a scrap one. They are different A arms.
jlgilmore
Nov 12, 2017 04:21 PM
deerhunter123
Nov 13, 2011 09:16 PM
5.0stang
Jul 9, 2008 01:03 PM
