150 baja atv
Old Oct 2, 2021 | 06:54 AM
Archiej254's Avatar
Default 150 baja atv
I when out today when I left oil was full,when I got back it was on the low end of the dipstick .
I am certain it whent out the valve breather (pipe goes over the frame then back to the ground)
anyone know why it’s happening?
Old Oct 3, 2021 | 03:33 AM
Check oil level again now it has stood, sometimes takes a while for oil to all drain back down. If it is using oil oil, check compression, as using oil is a symptom of worn piston rings and/or cylinder
JackTheKing
Jun 14, 2015 03:04 PM
nutso
Feb 27, 2007 01:35 AM
