Got new tires
Old Oct 25, 2021 | 05:12 PM
Kartjunkie's Avatar
5 Year Member
Default Got new tires
Got new tires last week. There are 3 lines around the outside of the tire. Both front tires in this pic have the lines on the left side.. Should the lines be in this position?
Old Oct 26, 2021 | 03:09 AM
It is getting a bit of a nightmare, as on directional tyres, lines should be the same on the same axle as you show. On non directional it doesn't matter. Never come across it on ATVs but there is a third type used on cars, with an inside and outside (asymmetric tread) where your set up would be wrong.
Old Oct 26, 2021 | 09:51 AM
Looks like Bighorns or a copy of that pattern. It's a tire that looks the same either way you mount them. They'll work fine the way they are.
Old Oct 26, 2021 | 10:56 AM
Kartjunkie's Avatar
5 Year Member
Ok thanks. Guess I'll have to brake them in. Two seconds on pavement and it felt like it was in 4wd. Ofcourse the old set were warn pretty good and a different tread pattern.
Old Oct 27, 2021 | 03:14 AM
That is why fitting fat tyres on the front of a non power steering Quad is not a good idea. On some the extra width doesn't seem to affect steering but a friend has 10" wides on his current model 420ES and it is really heavy on the steering.His brother has the same on a 420 Auto with power steering, and it is fine. Incidentally some, at least, of those Bighorn style tyres are directional as I found out after fitting a set to the rims then noticing a little arrow on the sidewalls.
Old Oct 27, 2021 | 12:02 PM
Kartjunkie's Avatar
5 Year Member
26x10-12 TriloBite HD 8-Ply tires with ITP Steel wheels on the rear.
26x9-12 TriloBite HD 8-Ply with ITP Steel wheels on the front.
Here's a couple pics. Only arrows I see are pointing up.
Old Oct 28, 2021 | 03:34 AM
Can't see any arrows, so I would guess they are non directional. Those ITP wheels, the offset correct? Standard tyre width is 8" so I guess 9" wide on front could make it a bit heavy. You can never tell, as I had a customer complain about the steering on a standard Suzuki 400 KQ, he also said he wanted bigger tyres on it. It was bad, as if in 4WD all the time, I was about to play with front diff, thinking the limited slip was faulty, when I thought, why not try it on the fat tyres first. Did so and the steering instantly improved.
bigcountry78
Jul 3, 2020 02:55 PM
Jun 13, 2019 02:19 AM
jetmotoracer
Feb 22, 2008 04:07 PM
magnumLover
Sep 12, 2006 11:18 AM
