2007 Sportsman 450 loose prop shaft
Old Nov 1, 2021 | 06:30 PM
Fulmer's Avatar
Default 2007 Sportsman 450 loose prop shaft
Last year I replaced the prop shaft on my 2007 Sportsman 450 with a new, OEM shaft because both U-joints were shot. I noticed the other day that the shaft is now loose on the transmission output shaft. The attached video is where the shaft attaches to the output shaft. I even pushed the rubber o-ring inside the groove on the shaft which slightly reduced the movement.
How much movement can I get away with before I must replace the output shaft (Snorkel Shaft)
How easy is the snorkel shaft to replace? Do I just loosen the 2 1/4 inch Tube-Snorkel and pull it out?
Thank you for any help
File Type: mpg
Polarisman1123
Feb 21, 2015 02:31 AM
alleys_daddy
Dec 4, 2013 02:04 PM
C-130 Crew Chief
Mar 11, 2013 06:29 AM
Coyotechaser
Aug 27, 2004 12:48 AM
