LT 80 crank seal falling out ???
Old Jan 20, 2022 | 06:47 PM
Ctd3720's Avatar
Default LT 80 crank seal falling out ???
Hello all !
ok hi again everyone I need some help...
I got my son's LT 80 about 7 years ago..
Had a bad crank seal was dry and fell off...
Put a new one in and shaved head .30
removed 2 rollers.
Fast forward to now...
about 5 years later quad has only been ridden a hand full of times...
Had some free time a was finishing some mods, cut rear shoes to 180 grams, Ported Reed cage and put in boysen reeds,, and dropped main jet to a 90..
Then I saw oil leaking out of the hole on the stator side..
Took it all apart and the new seal had came out ?? Just sitting there??
what pushed it out ?? Bad rings ??
Did a compresson check and at 55 ish ??
I read some where Jack Moore Said 90 min. Is what you need...
The weird thing is the thing runs really well ??
Do I need a top end??
Jack are you out there ??
Can we talk about stage 2 and be done with it ??
Anybody else have any ideas ?
Thank you,
Chris
How i found the crank seal...
Old Jan 24, 2022 | 04:10 AM
I was hoping Jack would come in on this. "The boss" has just bought an LTA50 with engine in bits. It had lost compression and previous owner had stripped the motor and then lost interest. I found piston & rings were fine but crank seal had popped, much like yours. centre punch marks round the outside of the seal housing would indicate it had done this before. I too am wondering why. New seal was very tight going in.
Old Jan 26, 2022 | 11:58 PM
Ctd3720's Avatar
Default Rookie mistake....
OMG...
Re connect the ground !!!
Yeah... I had ground off on the top right screw of the stator cover.
Now I get full juice to starter... 120+ for compression...
Still doesn't answer the seal falling out question....
Thanks and hope this helps someone...
Old Jan 28, 2022 | 10:46 AM
LT80's Avatar
LT80 Expert
Seals on LT80's don't usually have much problems. The LT50 seem to have that problem a lot more.
johnrayner1990
Jan 2, 2014 05:20 PM
jbudstew1
Jun 25, 2012 06:33 AM
itsjustagreat1
May 11, 2010 08:15 AM
wizard1212
Technical and How-To Articles
Dec 5, 2007 12:23 AM
800screws
Jul 1, 2004 07:37 AM
