Lateral Movement of Front tires
Old Jun 14, 2022 | 11:48 AM
amateur mech.'s Avatar
Default Lateral Movement of Front tires
I have a 2008 polaris sportsman 500 2X . With the front end jacked up, holding tire at 12 and 6 position I get very little movement on the front tires. However, when I hold tire at 9 and 3 position I get more movement. Not sure what parts need to be replaced.
Old Jun 21, 2022 | 02:36 AM
Probably track rod ends, not sure if your machine has power steering, if so they always have a little play, part of the way they work. Take the wheels off and wiggle the stub axles, you should be able to see where the play is, outer track rod ends, inner track rod ends or the steering column itself.
jeepcreeptj
Utility ATVs
Aug 1, 2013 04:49 PM
Rude Robert
Oct 28, 2010 02:40 PM
(FX4)
Nov 13, 2009 01:58 PM
Jason762
Nov 18, 2008 08:30 AM
sheepdogMSP8117
Jun 10, 2008 08:07 AM
