2015 Sportsman 570 Valve Adjust TDC question
Old Jul 7, 2022 | 12:03 AM
BFFs's Avatar
Default 2015 Sportsman 570 Valve Adjust TDC question
So I have had the cams out a few times and need to know how I make sure I am on the compression stroke when installing the cams. Is there a wasted spark and no overlap when the cams are spinning or do I need to make sure I am on the compression stroke before I install the cams back in. FYI...the shim Tappet set up Polaris has with these units is silly...costme $100 for new shim/tappets instead of just grabbing the 9.48mm shims I have in my kit. frustrating.
Thanks for any help!
Joe
Reno 5150
Jan 22, 2008 04:15 PM
confusedbuyer
Aug 1, 2004 01:50 PM
CHEWBACCA
Jun 20, 2004 10:03 AM
lrgmth
Oct 28, 2003 09:49 PM
duck43
Jun 16, 2001 10:23 AM
