Computer reset instructions
Old Aug 16, 2022 | 10:57 AM
2005TRX400FA5's Avatar
Default Computer reset instructions
Hello all thanks for the add , I have an 05 trx 400 fa5 , I've cleaned all the connections and replaced the shift actuator motor and angle sensor and now the machine has a code six in the esp display and the wheeler will only click will not fire I looked up the instructions and only was given partial instructions was not told to preload the angle sensor or anything , can someone please help me with a full set of accurate directions to do this ? I have no way to take it to a dealer or anything soo I'm pretty well stuck , Tia for any help!!
Old Aug 19, 2022 | 02:33 AM
Meant to check with the workshop manual at work, but forgot. I have the Haynes book for the old 500FA here and this is what it says. Align the angle sensor with the slot in the shaft. Turn sensor clockwise until it aligns with the bolt holes and fit the bolts.
System re-set:- Put shift lever in neutral, Start engine and let idle for 30 sec, put in drive, making sure dash shows D. Move forwards for 5 feet. Stop, move shift lever to neutral making sure display shows N and turn engine off. Hold both up and down switches down at the same time, switch ignition on, when N comes up on dash, let go of shift buttons, then press and release, up, then down, then up again, you should see a dashed line appear on display and shift motor will whir. within 5 sec, press throttle to full and off again. You should now see N on dash.
COOP76
Mar 4, 2025 06:25 PM
dwint
Jun 8, 2022 02:07 AM
goyard74
Aug 20, 2020 11:49 AM
hollie
Aug 20, 2020 11:43 AM
