Kill Switch Question
Old Sep 28, 2022 | 07:37 PM
djshad1469's Avatar
Default Kill Switch Question
I picked up an Eton 50 Quad. Got it running, but can't turn it off. The key needs to be on to start, but won't turn it off. The switch on the handle bars won't do it either. I watched a couple videos and thought I could put a toggle switch between the wire from the CDI to the coil, but as soon as I did it killed the CDI. I've found a wiring diagram, but it's tough seeing the wire colors to try and track down what goes where. Is there a simple way I can do this?
Old Sep 29, 2022 | 01:52 AM
Yes, Etons were "different" they used an earth to run ignition switch and kill wire, almost all other Chines/Taiwanese bikes are earth to kill. You could put another switch in the kill wire to cut power to the CDI and kill it, or in either exciter coil wire, or trigger coil wire, to CDI, or simply buy the correct CDI. If you do have the correct CDI and it is doing this, someone must have fitted a non genuine ignition switch.
Old Sep 29, 2022 | 05:53 PM
djshad1469's Avatar
Thanks to Merryman for the heads up on possibly having the wrong key switch. I was able to sort out the original wiring and move around the new switch wiring to be able to get it to turn off.
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
s10blazed
Oct 7, 2013 02:28 PM
Kiwi_Craig
Jul 11, 2002 04:00 PM
250rampage
Jun 29, 2001 04:57 PM
