Hisun 400XL 4wd 2012 burns difflock light all the time
Old Oct 15, 2022 | 12:26 PM
monstertruck76's Avatar
Default Hisun 400XL 4wd 2012 burns difflock light all the time
When i put power on it takes couple seconds and difflock light starts to burn but His is 2wd. I opened the front servomotor unit but no help. Fuses are ok, Relays are ok. Power is on limpmode when the difflight burns.. Whatta hell is problem. Will it help if i brake the light from the dash...
Old Oct 16, 2022 | 02:54 AM
Don't know that machine at all but the warning lights are usually operated by a switch on the diff. When 4WD goes in the mechanism in the diff operates a switch, and when diff lock goes in it operates another. If this switch is faulty or the wire from it shorted, it may be telling the computer lies, and bringing in fault mode. Find the switch and disconnect it, if that doesn't fix it, trace that wire and find if it is shorted out somewhere.
ranferg
May 25, 2018 09:37 PM
Patsplace
Apr 8, 2009 04:22 AM
buckley482
Jan 7, 2009 07:06 PM
Lincous
Sep 23, 2003 10:51 PM
