Linhai 400 (2011) misfires when in revers
Old Jan 7, 2023 | 11:59 AM
Flemm_NOR's Avatar
Default Linhai 400 (2011) misfires when in revers
I have a weired issue with my Linhai.
When I put it in revers and start driving backwards, it starts to misfire. This is not an issue when I go forward.
Have anyone else had this kind of issue and did you find out why?
Thanks in advance for help.
Old Jan 8, 2023 | 02:52 AM
A lot of bikes have a rev limiter when in reverse, unless you keep the revs down, the bike will misfire and pop. Other possibility is a bad earth on engine. As torque is reversed, the engine moves slightly in response, So a bad earth may get worse while the engine is loaded that way.
Old Jan 8, 2023 | 08:10 AM
Flemm_NOR's Avatar
Originally Posted by merryman
A
ok, I will check the grounding cable. This is a new problem, so I do not think it is the rev limiter that is causing this, or it can be. Maybe some water has penetrated some connection 🤔
squeege
Nov 7, 2006 10:43 AM
yoda
Jul 9, 2005 11:29 PM
1prokiwi
Oct 21, 2001 08:50 PM
