Bought Chinese quad, it has no ignition switch help
Old Jan 9, 2023 | 05:48 AM
Project's Avatar
Default Bought Chinese quad, it has no ignition switch help
Hi all, I've bought a quad (110cc hymoto?)
Bought it for a charity group to hopefully haul bits around a woodland.
I knew it didn't have the ignition/start stop w switch before buying, I thought I could just buy that part bolt on and plug n play... But....
I cannot find one to fit, I've bought a generic one that fits to handle bar but want to check wiring.
Colours are totally off.
On quad it's green/black
Pink
Blue/red
Red/white
Green/red
Can someone please explain these in simple terms and which are needed to switch on. And kill.
Thanks in advance
Old Jan 10, 2023 | 03:36 AM
Sorry but those colours are very non standard. Most Chinese bikes use Honda's colour codes. Black/white for kill wire, green for earth etc. None of those wires comply with what Honda use for ignition, except possibly pink, which is sometimes live from main fuse. If you can't get hold of the correct wiring diagram, all you can do is trace where each wire comes from, to find out its function. Fist check if your ignition system is AC or DC as a totally different key system is used for the two types. Five wires is unusual too, and may indicate a combined ignition and light switch.
Old Jan 10, 2023 | 03:42 AM
Project's Avatar
Certainly a challenge, I can trace wires if I strip plastics off, I'll try that when dry if no one else has come across such. Thanks for repjy
Old Jan 11, 2023 | 03:06 AM
Easier to look for wires of the right colour in other places and "bell them out" to check if they are the same wire, or connected to the same wire.
110ccAtv
Nov 27, 2021 04:08 AM
Dark lotus
1) Engine problems..
Apr 26, 2014 11:14 AM
ndnflyr
Jun 13, 2013 02:38 PM
bolt500
Mar 10, 2013 02:11 PM
jcerda1229@att.net
Nov 25, 2012 12:25 PM
