warn or superwinch?
Old May 3, 2001 | 02:46 PM
groundhog's Avatar
i'm wanting to buy a winch and have looked at all of them.kinda leanin toward superwinch atv2000 because of the big price difference.is the superwinch ok or should i go with the warn?.will only use it occassionally on my farm or when i get stuck . also should i replace the factory battery with a heavier duty one or will the stock one be ok?
thanks alot
Old May 3, 2001 | 03:36 PM
tempest's Avatar
The overwhelming response that you will receive is to buy Warn. I have a Superwinch and use it in much the same fashion as you intend and it has always worked fine for me.
Temp
Old May 3, 2001 | 03:38 PM
DeadEye's Avatar
Warn makes a better product in my opinion, but I purchased the 1500 due to price. It has never left me stranded and has really never messed up except when I did something wrong. Just remember: ALWAYS respool the winch staight and tight!
Old May 3, 2001 | 03:39 PM
DeadEye's Avatar
Warn makes warn makes a better product in my opinion, but I purchased the 1500 due to price. It has never left me stranded and has really never messed up except when I did something wrong. Just remember: ALWAYS respool the winch staight and tight!
Old May 3, 2001 | 05:09 PM
4x4king's Avatar
I had a superwinch on my quadrunner, and it always ran out of power. I now have one on my 300 4x4, but only because I got it used off of a friend for $100, plus a plow. If I had the money, I would have a Warn. I think they are built better and have better switches, which i have on my Honda. I hate those rocker switches. I had two pop out because they got muddy.
Old May 3, 2001 | 06:12 PM
Joe4x4Foreman's Avatar
I bought the Superwinch T-1500 for $109. The only trouble I've had was with 2 rocker switches. I changed over to the rotary switch by Superwinch and no more problems. I use it to lift/lower a snow plow and for occasional pulling. The stock battery got toasted when the rocker switches shorted repeatedly but no trouble with the replacement battery or rotary switch. Warn has a better product it seems but is quite pricey. Overall, I'd buy a Superwinch again, with a decent switch, that is.
Old May 4, 2001 | 07:11 AM
packrat's Avatar
I have a 2000lb superwinch on my H.O. and it seems to have plenty enough power. I have had no problems with the winch or the switch.But you know what they say "you get what you pay for".
Old May 4, 2001 | 07:41 AM
Code54's Avatar
I have the 25000 lbs Warn. I don't use it much, mostly to pull other people out on large group trail rides and such. Here is how I figured out what to by. The Warn was about $320 out the door. I have a HUGH relay, comes with a rollor fairlead, great remote control and a winch that has MORE then enough power. The way I use it I figure it should be around for the next 20 years, so that breaks down to what, about $16 a year. Plus I can always remount it on a different quad if I choose, so why buy the smaller one or bottom model then "wish" you had the nicer one for the next 20 years. (I did buy a superwinch 1500, looked it all over then decided it was just too light duty and returned it to get my Warn). It took me an extra month to get the extra money saved up but I think it was worth it.
Good luck and happy riding!!!
Old May 4, 2001 | 09:37 AM
sxr6's Avatar
After 3 Superwinches, 1 Ramsy, & now a Warn I'd deffinatly say go Warn!!! You usually get what you pay for.
Old May 5, 2001 | 10:29 PM
Rancher4x4ESLuvr's Avatar
Go for the warn, the SUPERWINCH is just built cheap. The switches allways go.. Why buy it and have problems just to save money.. Hey isnt that why we all buy HONDA?
Ride smart..
Jeff Roper
Feb 1, 2022 11:48 AM
Hondapolaris8596
Jul 28, 2016 03:17 PM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
MNatv89
Aug 10, 2015 02:20 PM
